Line object
Class AcadLine
Member of BricscadDb
The Line object represents a single line segment. To create a line, use the AddLine method. To edit or obtain information about a line, use the following methods and properties:
Methods Properties
ArrayPolar Angle
ArrayRectangular Application
Copy Document
Delete Delta
Erase EndPoint
GetBoundingBox Handle
GetExtensionDictionary HasExtensionDictionary
GetXData Hyperlinks
Highlight Layer
IntersectWith Length
Mirror Linetype
Mirror3D LinetypeScale
Move Lineweight
Offset Normal
Rotate ObjectID
Rotate3D ObjectName
ScaleEntity OwnerID
SetXData PlotStyleName
TransformBy StartPoint
Update Thickness
  TrueColor
  Visible
