Class AcadMText
Member of BricscadDb
The MText object represents multi-line text, or a paragraph of characters that fits within a boundary. To create an MText object, use the AddMText or method. To modify or obtain information about a point entity, use the following methods and properties:
Methods | Properties | Events |
ArrayPolar | Application | Modified |
ArrayRectangular | AttachmentPoint | |
Copy | BackgroundFill | |
Delete | Document | |
GetBoundingBox | DrawingDirection | |
GetExtensionDictionary | Handle | |
GetXData | HasExtensionDictionary | |
Highlight | Height | |
IntersectWith | Hyperlinks | |
Mirror | InsertionPoint | |
Mirror3D | Layer | |
Move | Linetype | |
Rotate | LinetypeScale | |
Rotate3D | Lineweight | |
ScaleEntity | Normal | |
SetXData | Parent | |
TransformBy | PlotStyleName | |
Update | Rotation | |
StyleName | ||
TextString | ||
Visible | ||
Width |
© Menhirs NV. All rights reserved. |
