Class AcadCircle
Member of BricscadDb
To access the Region object, use the following methods and properties:
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | Area |
Boolean | Centroid |
Copy | Document |
Delete | Handle |
Explode | HasExtensionDictionary |
GetBoundingBox | Layer |
GetExtensionDictionary | Linetype |
GetXData | LinetypeScale |
Highlight | Lineweight |
IntersectWith | Material |
Mirror | MomentOfInertia |
Mirror3D | Normal |
Move | ObjectID |
Rotate | ObjectName |
Rotate3D | OwnerID |
ScaleEntity | Perimeter |
SetXData | PlotStyleName |
TransformBy | PrincipalDirections |
Update | PrincipalMoments |
ProductOfInertia | |
RadiiOfGiration | |
TrueColor | |
Visible |
© Menhirs NV. All rights reserved. |
