Creates a box as a polyface mesh (Classic); Creates box as a 3D solid (Pro and Platinum).
command bar: box
menu bar: Model | 3D Solids | Box
toolbar: 3D Solids |
: box
Center/<Corner of box> <0.0000,0.0000,0.0000>: (Pick a point, or enter an option.)
Cube/Length/<Opposite corner>: (Pick another point, or enter an option.)
Height of box: (Pick two points, or enter a height.)
Specifies one corner of the box's base. Enter x,y,z coordinates or pick a point in the drawing. |
Specifies the center of the box's base. Enter x,y,z coordinates or pick a point in the drawing. |
Specifies a box with equal sides: Length of sides of cube - enter a length, or pick two points. |
Specifies the lengths of each side: Length of side of box - specify the length in the x direction. Width of box - specify the length in the y direction. Height of box - specify the length in the z direction. You may enter negative values to draw the box in the downward directions. |
Specifies the opposite corner of the box's base. Enter x,y,z coordinates or pick a point in the drawing. |
Specifies the height of the box. Enter a length or pick two points in the drawing. |
Grips Editing
Boxes can be edited directly through grips:
Select the box. Notice that it has many grips.
Drag any grip to move the box. (All eight grips perform the same function: move.)
XBox - creates a three-dimensional X-Solid box.
Sphere - creates 3D balls as solid models.
