Creates a torus as a polygon mesh (Classic); creates a torus as a 3D solid (Pro and Platinum).
command bar: torus
menu bar: Model| 3D Solids | Torus
toolbar: 3D Solids |
: torus
Center of whole torus: <0,0,0> (Pick a point, or enter coordinates.)
Diameter/<Radius of whole torus>: (Specify the radius, or type D.)
Diameter/<Radius of body of torus>: (Specify the radius, or type D.)
Specifies the center of the torus; press Enter to accept the default coordinates. |
Specifies the overall radius of the torus; note that the distance is measured to the center of the tube (body). |
Specifies the radius of the torus body, or tube. It is not necessary for the body radius to be smaller than the whole radius. |
Specifies the diameters of the whole torus and/or body. |
XTorus - Creates a torus as a 3D X-Solid.
Sphere - creates 3D balls as solid models.
