Ai_Cylinder
Draws 3D cylinders as 3D mesh surfaces, with round or elliptical bases.
command bar:  ai_cylinder
menu bar:  Model | Meshes | Cylinder
toolbar:  Meshes |
: ai_cylinder
Elliptical/Divisions/<Center of base of cylinder> <0,0,0>:  (Pick a point, enter coordinates, or enter an option.)
Diameter/<Radius of cylinder>: (Specify radius, or enter D.)
Center of second end/<Height of cylinder>: (Specify height, or enter C.)
Specifies the center point of the cylinder's base; the base is drawn on the current x,y-plane.
Radius of cylinder
Specifies the radius of the cylinder.
Height of cylinder
Specifies the height of the cylinder (in the z direction); enter a negative number to draw the cylinder downwards.
Specifies coordinates for the other of the cylinder, an alternative to specifying the height. Prompts you:
Center of second end  -s specify the other end of the cylinder by pointing or entering a height.
Diameter
Specifies the diameter of the cylinder's base. Prompts you:
Diameter of cylinder - specify the diameter by pointing or entering a value.
Divisions
Changes the number of isolines used to simulate the cylinder's curved surface. Prompts you:
Number of divisions - change the number of isolines from the default of 16.
Elliptical
Specifies that the cylinder should have an elliptical cross-section. Prompts you:
Center specifies the center of the ellipse.
First end of ellipse axis - specify the endpoint of one ellipse axis.
Second end of ellipse axis - specify the other end point of the first axis.
Other axis - specify the length of the second axis.
Grips Editing
Mesh-formed cylinders can be edited directly through grips:
  1. Select the cylinder. Notice that it has several grips.
  2. Drag a grip to stretch the adjacent faces.
Ai_Dish -  draws 3D dishes as mesh surfaces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
