RevSurf
Creates a 3D mesh surface by revolving a linear entity around a line.
command bar:  revsurf
menu bar:  Model | Meshes  | Revolved Surface
toolbar:  Meshes | 3D Surfaces |
: revsurf
Select a linear entity to revolve: (Pick a single entity.)
Select the axis of revolution: (Pick a line.)
Angle to begin surface of revolution <0>: (Specify an angle, or press Enter to accept the default.)
Degrees to revolve entity (+ for ccw, - for cw <360>: (Specify an angle with an optional negative sign, or press Enter to accept the default.)
Specifies a single entity to be revolved into a 3D surface mesh.
You may choose a line, circle, arc, polyline, or spline; 3D objects do not work.
Specifies the entity about which the surface is revolved; you may choose a line or polyline; curved objects do not work.
Specifies the starting angle of the revolution; the default is 0 degrees.
Specifies the extent of the revolution; for a closed object, start with 0 and end with 360 degrees.
The revolved surface is drawn counterclockwise; prefix the angle with a negative sign to draw the revolution clockwise.
Note that this is not the ending angle, but the number of degrees by which the entity is revolved.
Ai_Dish -  draws 3D dishes as mesh surfaces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
Sweep - creates a 3D solid by sweeping a closed 2D entity along a path.
