Ai_Torus
Draws a torus as a 3D mesh surface.
command bar:  ai_torus
menu bar:  Model | Meshes | Torus
toolbar:  Meshes |
: ai_torus
Center of whole torus: <0,0,0> (Pick a point, or enter coordinates.)
Diameter/<Radius of whole torus>: (Specify the radius, or type D.)
Diameter/<Radius of body of torus>: (Specify the radius, or type D.)
Specifies the center of the torus; you can press Enter to accept the default coordinates.
Specifies the overall radius of the torus; note that the distance is measured to the center of the tube (body).
Specifies the radius of the torus body, or tube. It is not necessary for the body radius to be smaller than the whole radius.
Diameter
Specifies the diameters of the whole torus and/or body.
Grips Editing
Mesh-formed torus surfaces can be edited directly through grips:
  1. Select the torus. Notice that it has one grip at each vertex.
  2. Drag the grip to move the adjacent faces.
Ai_Dish -  draws 3D dishes as mesh surfaces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
