Ai_Dish
Draws the bottom half of a sphere as a 3D mesh surface.
command bar:  ai_dish
menu bar:  Model | Meshes | Dish
toolbar:  Meshes |
: ai_dish
Center of dish: (Pick a point or enter coordinates.)
Diameter/<Radius of dish>: (Pick a point, enter coordinates, or enter R.)
Number of divisions around dish <16>: (Enter a number, or press Enter to keep the default value.)
Number of top-to-bottom divisions <8>: (Enter a number, or press Enter to keep the default value.)
Center of dish
Specifies the center point of the dish's open end; the end is drawn on the current x,y-plane.
Radius of dish
Specifies the radius of the dish.
Changes the number of horizontal isolines used to simulate the dish's curved surface.
Changes the number of vertical isolines from the default of 8.
Diameter
Specifies the diameter of the dish. Prompts you:
Diameter of dish - specify the diameter by pointing or entering a value.
Grips Editing
Mesh-formed dishes can be edited directly through grips:
  1. Select the dish. Notice that it has several grips.
  2. Drag a grip to stretch the adjacent faces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
