ExpUcs
Creates, modifies, and deletes named UCSs through the Drawing Explorer (short for "explore user-defined coordinate systems").
command bar:  expucs
alias:  uc, dducs, explorer
menu bar:  Tools | Drawing Explorer | Coordinate Systems
: expucs
Displays the UCS section of the Drawing Explorer dialog box:
Create or modify named UCSs, and then click X.
Press F1 to access help.
UCS Name
Lists the names of UCSs in the drawing; click to rename.
UCS is short for "user-defined coordinate system."
Origin (WCS)
Reports the origin (0,0,0) of the UCS in x,y,z coordinates of the WCS; cannot be edited.
WCS is short for "world coordinate system."
X Axis Direction (WCS)
Reports the direction of the x axis in WCS coordinates; cannot be edited.
Y Axis Direction (WCS)
Reports the direction of the y axis in WCS coordinates; cannot be edited.
Current
Indicates the current UCS.
Toolbar Icons
New
Creates a new UCS; dismisses the Drawing Explorer, and then runs the Ucs command. See Ucs command.
Erase
Deletes the selected UCS; the current UCS cannot be erased.
Ucs - creates and modifies user-defined coordinate systems.
UcsIcon - controls the appearance of the UCS icon.
SetUcs - sets the UCS to a specified viewpoint.
Plan - changes the viewpoint to the plan view of the WCS or current UCS.
DdVPoint - changes the 3D viewpoint of the drawing through a dialog box.
VPoint - changes the 3D viewpoint of the drawing through the command bar.
Settings - sets parameters of UCSs.
