SetUCS
Sets the UCS to a specified viewpoint (short for "set user-defined coordinate system").
command bar:  setucs
aliases:  dducsp, ucp
menu bar:  Settings | Set UCS
toolbar:  Settings |
: setucs
Click on a button; the dialog box disappears automatically.
Use the UCS command's View option to name the UCS generated by this command.
Set the selected UCS relative to
Specifies how the new UCS is set:
Current UCS
THe UCS is set relative to the current UCS.
World Coordinate System
The UCS is set relative to the WCS.
WCS is short for "world coordinate system." The WCS is the default coordinate system when no UCS is set; it cannot be changed.
Change view to plan view of the selected UCS
Toggles whether the plan view is displayed when switching UCSs:
Yes - plan view is displayed.
No - the viewpoint does not change.
Plan view looks down the z axis at the x,y plane.
Select UCS
Sets the UCS to one of the following coordinate systems. Clicking one of these buttons sets the UCS, and then immediately exits the dialog box.
Previous UCS
Changes the UCS to the previous UCS.
Current View
Changes the UCS to match the current viewpoint.
Set to WCS
Changes the UCS to match the WCS.
Planar UCSs
Sets the UCS to one of the following standard views. Clicking one of these buttons sets the UCS, and then immediately exits the dialog box.
 Top
Changes the UCS to match the top view.
 Left
Changes the UCS to match the left view.
 Front
Changes the UCS to match the front view.
 Bottom
Changes the UCS to match the bottom view.
 Right
Changes the UCS to match the right view.
 Back
Changes the UCS to match the back view.
Cancel
Closes the dialog box without changing the UCS.
Ucs - creates and modifies user-defined coordinate systems.
UcsIcon - controls the appearance of the UCS icon.
ExpUcs - creates, modifies, and deletes named UCSs through the Drawing Explorer.
Plan - changes the viewpoint to the plan view of the WCS or current UCS.
DdVPoint - changes the 3D viewpoint of the drawing through a dialog box.
VPoint - changes the 3D viewpoint of the drawing through the command bar.
Settings - sets parameters of UCSs.
