Fillet
Fillets intersections; joins intersecting lines with an arc of any suitable radius.
command bar:  fillet
alias:  f
menu bar:  Modify | Fillet
toolbar:  Modify |
: fillet
Fillet (radius=0.5000): Settings/Polyline/Radius/Trim/Undo/Multiple/<Select first entity>: (Choose an entity, enter an option, or enter R to change the radius.)
Select second entity: (Choose another entity.)
Fillets can be applied to intersecting, non-intersecting, and parallel lines.
Fillets are applied to all vertices of a polyline.
Select first entity
Choose an entity, or enter R to change the radius. The following entities can be filleted:
  • Lines, including parallel lines.
  • All vertices of a single 2D polyline; two polylines cannot be filleted.
  • Rays, including parallel rays.
  • Infinite lines, including parallel infinite lines.
  • Arcs.
  • Circles.
Choose the second entity.
Settings
Displays the Chamfer/Fillet section of the Settings dialog box:
  • Fillet radius - sets the radius of the fillet arc.
  • Trim mode - toggles whether the entities are trimmed back to the fillet radius.
Polyline
Fillets the vertices of a polyline; prompts you:
Select 2D polyline to fillet - choose a single polyline.
You cannot control which vertices are filleted; all are.
Radius
Prompts you to type the Fillet radius in the command bar.
Trim
Prompts you to set the Trim mode in the command bar.
Undo
Undoes the last fillet when in Multiple mode.
Multiple
Lets you create multiple fillets using the same settings.
Procedures
Filleting two entities or polyline segments
Filleting all vertices of a polyline
Filleting two parallel lines
Break - cuts parts out of entities.
Chamfer - chamfers intersections.
Settings - specifies parameters for fillets.
SolidEdit - edits faces, edges, and bodies of solid models.
Trim - trims entities where they cross other entities.
