LWeight
Controls the display of lineweights in the drawing through the Settings dialog box.
command bar:  lweight
toolbar:  Entity Properties |
status bar:  LWT
: lweight
Displays the Lineweights section of the Settings dialog box:
Change settings, and then click X.
Lineweights can also be specified by the following commands:
Entity Lineweight
Specifies the lineweight for entities drawn from now on; choose a preset lineweight from the droplist.
This sets the current lineweight in the Entity Properties droplist and Properties palette.
Lineweights cannot be customized, unlike linetypes.
Default Lineweight
Specifies the default lineweight for all new drawings; choose a preset lineweight from the droplist.
Lineweight Display
Toggles the display of lineweights:
  • On - displays lineweights.
  • Off - does not display lineweights; all entities have the same lineweight.
Lineweight Units
Specifies the unit of measurement:
  • Millimeters - measures the width in millimeters.
  • Inches - measures the width in inches.
Lineweight Display Scale
Specifies the relative scale of lineweights; applies to lineweights in Model tab only.
Status Bar Menu
Right-click LWT on the status bar for the shortcut menu:
Shortcut Menu
On
Turns on lineweights.
Off
Turns off lineweights.
Settings
Opens the Lineweights section of the Settings dialog box.
Settings - sets lineweight parameters.
Layer - assigns lineweights to layers.
Properties - change lineweight through a palette.
Change and ChProp - change lineweight through the command bar.
Plot and Print - optionally plot entities with lineweights.
