Platinum
Platinum
Platinum
Inserts a Bill of Materials (BOM) table in the current drawing.
command bar: bmbom
menu bar: Mechanical | Bill Of Materials
toolbar: Mechanical |
: bmbom
Insertion point [Name/Top level/Bottom level]: (Specify the insertion point or enter an option.)
Top level (left) and bottom level (right) Bill of Materials of an 8 piston engine assembly.
Prompts you to type a name in the command bar: Table name <Default Name>: Type the name, then press Enter. Prompts you: Insertion point [Name/Top level/Bottom level]: Specify the insertion point or enter an option. |
Creates a BOM of the top level components. |
Creates a BOM of the subcomponents. |
Table - creates a table entity in the drawing through a dialog box.
-Table - creates a table entity in the drawing through the command bar.
Tabledit - Edits texts in a table cell.
BmBrowser - toggles the visibility of the Mechanical Browser window.
BmDissolve - dissolves a mechanical component inserted in the current drawing.
BmForm - creates a new mechanical component and inserts it into the current drawing.
BmHardware - inserts a standard hardware solid as a mechanical component in the current drawing.
BmHide - hides a mechanical component or subcomponent in the current drawing.
BmInsert - inserts an existing mechanical component into the current drawing.
BmMech - converts the current drawing into a mechanical main component.
BmNew - creates a new mechanical component as a new drawing file.
BmShow - shows a previously hidden mechanical component or subcomponent in the current drawing.
BmUpdate - reloads all referenced components from external files and updates BOM tables.
BmVStyle - applies a visual style to a mechanical component.
BmXConvert - converts X-Hardware solids in the current drawing to mechanical components.
© Menhirs NV. All rights reserved. |
