QNew
Opens new drawings in BricsCAD (short for "quick new").
command bar:  qnew
alias:  n
menu bar:  Name
toolbar:  Standard |
: qnew
Displays a dialog box that depends on the STARTUP system variable in the Settings dialog box:
When STARTUP = 1 (Display the Startup and Create new Drawings dialog boxes), shows the following dialog box:
See NewWiz command.
When STARTUP = 2 (Display the Select Template dialog box, or use default drawing template file):
See New command.
For Create New Drawing options, see NewWiz command.
For Select Template options, see New command.
Procedures
To create a drawing using a default template drawing
To set the default template drawing
To create a drawing from scratch
To set the Plot style policy
To create a drawing using a template drawing
To create a drawing using the New command
To set the Template Path variable
To create a drawing using a wizard
Units - sets units through the Settings dialog box.
-Units - sets units through the command bar.
NewWiz - sets units and other parameters for new drawings.
New - opens new drawings.
