Torus
Creates a torus as a polygon mesh (Classic); creates a torus as a 3D solid (Pro and Platinum).
command bar:  torus
menu bar:  Model| 3D Solids | Torus
toolbar:  3D Solids |
: torus
Center of whole torus: <0,0,0> (Pick a point, or enter coordinates.)
Diameter/<Radius of whole torus>: (Specify the radius, or type D.)
Diameter/<Radius of body of torus>: (Specify the radius, or type D.)
Specifies the center of the torus; press Enter to accept the default coordinates.
Specifies the overall radius of the torus; note that the distance is measured to the center of the tube (body).
Specifies the radius of the torus body, or tube. It is not necessary for the body radius to be smaller than the whole radius.
Diameter
Specifies the diameters of the whole torus and/or body.
Sphere -  creates 3D balls as solid models.
