DimRotated object
Class AcadDimRotated
Member of BricscadDb
A dimension measuring the radius of a circle or arc. To create a radial dimension, use the AddDimRotated method. To access the DimRotatel object, use the following methods and properties:
Methods Properties
ArrayPolar AltRoundDistance
ArrayRectangular AltSuppressLeadingZeroes
Copy AltSuppressTrailingZeroes
Delete AltSuppressZeroFeet
Erase AltSuppressZeroInches
GetBoundingBox AltTextPrefix
GetExtensionDictionary AltTextSuffix
GetXData AltTolerancePrecision
Highlight AltToleranceSuppressLeadingZeroes
IntersectWith AltToleranceSuppressTrailingZeroes
Mirror AltToleranceSuppressZeroFeet
Mirror3D AltToleranceSuppressZeroInches
Move AltUnits
Rotate AltUnitsFormat
Rotate3D AltUnitsPrecision
ScaleEntity AltUnitsScale
SetXData Application
TransformBy Arrowhead1Block
Update Arrowhead1Type
  Arrowhead2Block
  Arrowhead2Type
  ArrowheadSize
  Color
  DecimalSeparator
  DimensionLineColor
  DimensionLineExtend
  DimLine1Suppress
  DimLine2Suppress
  DimLineInside
  Document
  EntityName
  ExtensionLineColor
  ExtensionLineExtend
  ExtensionLineOffset
  ExtLine1Suppress
  ExtLine2Suppress
  Fit
  ForceLineInside
  FractionFormat
  Handle
  HasExtensionDictionary
  HorizontalTextPosition
  Hyperlinks
  Layer
  LinearScaleFactor
  Linetype
  LinetypeScale
  Lineweight
  Measurement
  Normal
  Parent
  PlotStyleName
  PrimaryUnitsPrecision
  Rotation
  RoundDistance
  ScaleFactor
  StyleName
  SuppressZeroFeet
  SuppressZeroInches
  TextColor
  TextGap
  TextHeight
  TextInside
  TextInsideAlign
  TextMovement
  TextOutsideAlign
  TextOverride
  TextPosition
  TextPrecision
  TextPrefix
  TextRotation
  TextString
  TextStyle
  TextSuffix
  ToleranceDisplay
  ToleranceHeightScale
  ToleranceJustification
  ToleranceLowerLimit
  TolerancePrecision
  ToleranceUpperLimit
  UnitsFormat
  VerticalTextPosition
  Visible
