Class AcadLeader
Member of BricscadDb
The Leader object represents a line leading from a feature of the drawing to an annotation, such as a dimension. To create a leader, use the AddLeader method. To access the Leader object, use the following methods and properties:
Methods | Properties |
ArrayPolar | Annotation |
ArrayRectangular | Application |
Copy | Color |
Delete | Coordinates |
Erase | Document |
GetBoundingBox | EntityName |
GetExtensionDictionary | |
GetXData | Handle |
Highlight | HasExtensionDictionary |
IntersectWith | Hyperlinks |
Mirror | Layer |
Mirror3D | Linetype |
Move | LinetypeScale |
Rotate | Lineweight |
Rotate3D | Normal |
ScaleEntity | Parent |
SetXData | PlotStyleName |
TransformBy | StyleName |
Update | TrueColor |
Type | |
VerticalTextPosition | |
Visible |
© Menhirs NV. All rights reserved. |
