Image object
Class AcadRasterImage
Member of BricscadDb
The Image object represents a raster image consisting of a rectangular grid of small squares or dots known as pixels. To create a raster image use the AddImage method. To edit or query a raster image, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular Color
Copy Document
Delete EntityName
Erase
GetBoundingBox Handle
GetExtensionDictionary HasExtensionDictionary
GetXData Height
Highlight Hyperlinks
IntersectWith ImageFile
Mirror ImageHeight
Mirror3D ImageVisibility
Move ImageWidth
Rotate Layer
Rotate3D Linetype
ScaleEntity LinetypeScale
SetXData Lineweight
TransformBy Origin
Update Parent
  PlotStyleName
  Visible
  Width
