InfiniteLine object
Class AcadXline
Member of BricscadDb
The InfiteLine object represents an line extending infinitely in both directions. To create an infinite line, use the AddInfiniteLine method. To access the Ellipse object, use the following methods and properties.
Methods Properties
ArrayPolar Application
ArrayRectangular BasePoint
Copy Color
Delete DirectionVector
GetBoundingBox Document
GetExtensionDictionary Handle
GetXData HasExtensionDictionary
Highlight Hyperlinks
IntersectWith Layer
Mirror Linetype
Mirror3D LinetypeScale
Move Lineweight
Offset PlotStyleName
Rotate SecondPoint
Rotate3D TrueColor
ScaleEntity Visible
SetXData
TransformBy
Update
