Attaches PDF files to the current drawing through the Drawing Explorer.
command bar: pdf
menu bar: Insert | Attach PDF...
toolbar: Insert |
Displays the Drawing Explorer - :
Name of the Pdf insert. This name is assigned by BricsCAD, but cannot be changed by the user. |
Toggles the loading of the Pdf:
Click to change the load status. |
Reports the size of the PDF files. |
Reports the number of times the PDF is inserted in the drawing. |
Reports the date of the file. This can be useful in determining if you ware working with the most recent revision. |
Reports the original path to the PDF file when first loaded. If the path cannot be found, click this field,
and then click the
Reports the current path to the PDF file. |
Launches the PDFATTACH command. |
Detaches the currently selected Pdfs |
Inserts another copy of the Pdf. Displays the Attach Pdf Underlay dialog box.
Displays the details of Pdfs. |
Displays an icon for each Pdf. |
Displays the relationship between the current drawing and the Pdfs in a tree-like view: |
PdfAdjust - Allows to adjust the fade, contrast and monochrome settings of a PDF-underlay in the command bar.
PdfAttach - inserts a PDF file as an underlay into the current drawing.
Pdfclip - allows clipping of PDF underlays.
Pdflayers - allows to control the display of layers in a PDF underlay.
XRef - attaches and controls externally referenced drawings through the Drawing Explorer.
-XRef - attaches and controls xrefs through the command bar.
XClip - clips externally-referenced drawings.
Insert - inserts drawings as blocks.
Eplorer - opens the Drawing Explorer dialog box.
© Menhirs NV. All rights reserved. |
