Tool Palettes
Command: TOOLPALETTES,
TOOLPALETTESCLOSE,
TPNAVIGATE
The ToolPalettes command opens the
Tool Palettes bar.
The ToolPalettesClose command
closes the Tool Palettes bar.
The Tpnavigate command displays a
tool palette or a tool palette group.
On a tool palette you can add blocks, hatches and commands in a
tabbed window.
Drag a tool from the palette to the graphic screen to launch the
related tool.
To open the Tool Palettes Bar
Do one of the following:
Hover over a toolbar (Windows) or an empty
toolbar area (Windows and Linux), then right click and choose
Tool Palettes Bar in the context
menu.
Type toolpalettes in the command bar, then press
Enter.
To
set the view options
- Right click in an empty space of the icon area on
the Toolpalettes Bar and choose
View Options... in the context
menu.
The View Options dialog displays.
- Drag the Image Size
slider to adjust the image size.
- Select either Icon with
text, Icon only
or List view.
- Choose either Current
Palette or All Palettes from
the Apply to list button.
- Click the OK button
to confirm.
To
add a new tool palette
- Move the cursor to the icon area of the
Tool Palettes Bar, then right
click.
A context menu displays:
- Choose New Palette
in the context menu.
A new tab is added.
- Type a name for the new palette in the
Name field.
To open the customize dialog box
click.
- Choose Customize
Palettes in the context menu.
The Customize dialog box
displays:
To import a tool palette
- Open the Customize
dialog box.
- In the Palettes pane
on the Customize dialog box, right
click and choose Import in the
context menu.
- On the Import
Palette dialog, select a folder, then select a palette file
(*.btc or *.xtp).
- Click the Open
button or double click to import the palette.
The palette is added in the Palettes
list.
- Click the Close
button to close the Customize dialog
box.
Working with palette groups
To create a palette group
dialog box.
- Place the cursor on the Palette
Groups root folder name.
- Right click and choose New
Palette in the context menu.
A new group folder is added at the bottom of the palette groups
tree.
- Type a name for the new group.
To create a palette subgroup
dialog box.
- Place the cursor on an existing group name.
A new group folder is added as a subgroup of the selected
group.
To add a palette to a group
dialog box.
- Place the cursor on a palette.
- Press and hold the left mouse button, then drag
the palette onto a palette group name.
- Release the left mouse button to add the palette
to the group.
To remove a palette from a group
dialog box.
- Select the palette in the group.
- Right click and choose Remove in the context menu.
To set a palette group current
dialog box.
- Select the palette group in the palette groups
tree.
- Right click and choose Set
Current in the context menu.
To delete a palette group
dialog box.
tree.
- Right click and choose Delete in the context menu.
To rename a tool palette
- Right click tool palette tab and choose
Rename Palette in the context
menu.
- Type a new name for the palette in the
Name field.
- Press Enter to confirm.
To delete a tool palette
Delete Palette in the context
menu.
on the Confirm Palette Deletion
box.
Adding a hatch pattern
- Select the palette you want to add a hatch pattern
to.
- Open the
Hatch and Gradient dialog box.
- Select either Predefined or Custom from the Type list button.
- Double click the Swatch field on the Hatch
The Hatch Pattern Palette
displays.
- Select the hatch pattern you want to add, then
right click and Choose Add to Current Tool
Palette.
The hatch pattern is added on the current tool palette.
- (option) Repeat steps 5 and 6 to add more hatch
patterns.
- (option) Drag-and-drop patterns to change their
order on the palette.
Adding a
block
Blocks can be added from the current drawing or from any
drawing.
To add a block from the current drawing:
- Choose Drawing Explorer -
Blocks in the Tools menu.
- On the Drawing Explorer -
Blocks dialog box select the block or blocks you want to
add.
- Right click and choose Add
to Current Tool Palette in the context menu.
To add a block from any drawing:
- If not already available, add the containing
folder to the Folders
list on the Drawing Explorer -
Drawings dialog box.
- Select the drawing in the containing folder on the
Drawing Explorer - Drawings
dialog box.
- Click the Expand
icon (+) of the containing drawing.
The Blocks icon of the drawing
displays.
- Click the Blocks
icon of the containing drawing.
The blocks in the drawing display in the Details pane.
- Select the block or blocks you want to add.
Press and hold the Ctrl key to select multiple blocks.
- Right click and choose Add to Current Tool Palette in the context
menu.
(option) Drag-and-drop blocks to change their order
on the palette.
To add a drawing as a block:
dialog box.
to Current Toolpalette as block in the context menu.
When placing a block from a toolpalette the -Insert
command is launched.
To add a drawing
as a component.
dialog box.
to Current Toolpalette as component in the context menu.
When placing a component from the tool palette, the -BmInsert
Adding a command
- Choose Customize in
the Tools menu.
- Under Available
Tools on the Customize dialog,
expand the containing toolbox, then select the command in the
commands list.
menu.
(option) Drag-and-drop commands to change their
NOTE
See the topic Creating
Custom Tools to create your own tools, which you can then add
to a tool palette.
Editing a
tool
General procedure to edit a tool on a tool palette:
- Right click the tool, then choose Properties in the context menu.
The Tool Properties dialog box
displays.
Hatch tool
properties
Block tool
properties
Command tool
properties
- Edit the tool properties.
to confirm.
Managing tools
To manage the tools on a tool palette do the following:
- Right click the tool.
- Choose an option in the context menu.
To specify a tool
- Right click the tool and choose Specify Image in the context menu.
A file dialog box displays.
- Select the image file, then click the Open button.
NOTE
To restore the original tool image: Right click the tool and
choose Remove Image in the context
menu.
To move a tool
Drag-and-drop tools to re-arrange tools on a palette: drag the
tool to the desired location and drop the tool on top of the
existing tool.
To move a tool from one palette to another, do the
following:
- Right click the tool on the source palette and
choose Cut in the context menu.
- Select the target palette.
- Right click and choose Paste in the context menu.
The tool is added at the bottom of the palette.
To copy a tool
To copy a tool from one palette to another, do the
following:
choose Copy in the context menu.
© Menhirs NV. All rights reserved. |
