Works with Classic, Pro
Creates a sphere as a 3D mesh surface in Classic; Creates a 3D solid sphere in Pro.
command bar: sphere
menu bar: Draw | 3D Entities | Sphere
toolbar: Solids |
: sphere
Center of sphere: (Pick a point, or enter coordinates.)
Diameter/<Radius of sphere>: (Specify a distance, or type D.)
Specifies the center point of the sphere; enter x,y- or x,y,z-coordinates, or pick a point in the drawing. |
Specifies the radius. |
Specifies the diameter. |
Grips Editing
Spheres can be edited directly through grips:
Select the sphere. Notice that it has one grip.
Drag the grip to move the sphere.
Sphere - creates 3D balls as solid models.
