Display a vertical column of radio buttons. DCL Cluster Tile
This cluster tile groups together one or more radio buttons in a vertical column. A radio_button tile must be placed either within this tile or within a radio_row cluster tile. Otherwise, the program does not know which radio buttons are related to each other.
NOTE A radio_column cluster can only contain radio buttons. Use the column cluster for other tiles.
Valid Attributes
Example
NOTE The value attribute indicates which radio button is currently selected, via the value of "1":
value = "1"
Related DCL Tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
