Specify the default value of a tile.
This attribute specifies the default value of a tile. The value depends on the type of tile.
string: a string; no default.
The following table summarizes the default value for each type of tile:
| Tile Type | Default Value |
| boxed_radio_column | Key of the selected radio button. |
| boxed_radio_row | Key of the selected radio button. |
| dialog | Optional text for the dialog box's title bar. |
| edit_box | Default text seen by the user in the edit box. |
| image | Default image seen in the image box. |
| list_box | Lists items that are initially highlighted. |
| popup_list | Lists items that are initially highlighted. |
| radio_button | "1" = button is on; "0" = button is off. |
| slider | Default value of the slider. |
| text | Text displayed by the tile. |
| toggle | "1" = checked or on; "0" = unchecked or off. |
Example
Valid Tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
