Specify a tile's label.
This attribute specifies the text of a tile's title; optionally, it specifies the tile's mnemonic. The position of the label depends on the type of tile; you cannot control its location. For no label, use " " as the string.
string: a string. The & (ampersand) prefix determines the mnemonic.
Examples
NOTE
Valid Tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
