Load that dialog box definition file.
This function loads a DCLdialog control file. DCL files must be loaded before a custom dialog box can be displayed by Bricscad. The filename argument is the name of the DCL file.
This function returns the following codes:
| Return Code | Meaning |
| 1 | DCL was successfully loaded. |
| -1 | DCL file was not found. |
Examples
| Code | Returns |
(load_dialog "basicdcl") |
1 |
(load_dialog "junkdcl") |
-1 |
NOTE The order of calling a dialog box is as follows:
Tell me about...
Programming Overview of LISP (LISt Processing) Language
