Ai_Cone
Draws 3D cones as mesh surfaces, with round or elliptical bases
command bar:  ai_cone
menu bar:  Draw | 3D Meshes | Cone
toolbar:  Draw 3D |
: ai_box
Elliptical/Divisions/<Center of base of cone> <0,0,0>:  (Pick a point, enter coordinates, or enter an option.)
Diameter/<Radius of base>: (Pick a point, enter coordinates, or type D.)
Apex/<Height of cone>:  (Pick a point, enter coordinates, or type A.)
Specifies the center point of the cone's base.
Radius of base
Specifies the radius of the cone's base.
Height of cone
Specifies the height of the cone (in the z direction); enter a negative number to draw the cone upside down.
Apex
Specifies coordinates for the top of the cone, an alternative to specifying the height. Prompts you:
Apex of cone - specify the top of the cone by pointing or entering a height.
Diameter
Specifies the diameter of the cone's base:
Diameter of base - specify the diameter by pointing or entering a value.
Divisions
Changes the number of isolines used to simulate the cone's curved surface. Prompts you:
Number of divisions - change the number of isolines from the default of 1.
Elliptical
Specifies that the cone should have an elliptical base. Prompts you:
Center specifies the center of the ellipse.
First end of ellipse axis - specify the endpoint of one ellipse axis.
Second end of ellipse axis - specify the other endpoint of the first axis.
Other axis - specify the length of the other (second) axis.
Grips Editing
Mesh-formed cones can be edited directly through grips:
  1. Select the cone. Notice that it has several grips.
  2. Drag a grip to stretch the adjacent faces.
Ai_Dish -  draws 3D dishes as mesh surfaces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
