Creates a 3D mesh surface by revolving a linear entity around a line.
command bar: revsurf
menu bar: Draw | Meshes | Revolved Surface
toolbar: Draw 3D | 3D Surfaces
: revsurf
Select a linear entity to revolve: (Pick a single entity.)
Select the axis of revolution: (Pick a line.)
Angle to begin surface of revolution <0>: (Specify an angle, or press Enter to accept the default.)
Degrees to revolve entity (+ for ccw, - for cw <360>: (Specify an angle with an optional negative sign, or press Enter to accept the default.)
Specifies a single entity to be revolved into a 3D surface mesh. You may choose a line, circle, arc, polyline, or spline; 3D objects do not work. |
Specifies the entity about which the surface is revolved; you may choose a line or polyline; curved objects do not work. |
Specifies the starting angle of the revolution; the default is 0 degrees. |
Specifies the extent of the revolution; for a closed object, start with 0 and end with 360 degrees. The revolved surface is drawn counterclockwise; prefix the angle with a negative sign to draw the revolution clockwise. Note that this is not the ending angle, but the number of degrees by which the entity is revolved. |
Ai_Dish - draws 3D dishes as mesh surfaces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
Bricscad™ коммерциализирован Bricsys NV. Bricsys NV и Vondle NV являются полностью дочерними компаниями Menhirs NV. Авторские права © 2001- Menhirs NV - Все права защищены. |
