RuleSurf
Creates 3D mesh surfaces by connecting two separate linear entities.
command bar:  rulesurf
menu bar:  Draw | Meshes | Ruled Surface
toolbar:  Draw 3D | 3D Surfaces |
: rulesurf
Select entity to define first end of ruled surface: (Select an open object.)
Select entity to define other end: (Select another open object.)
Specifies the first boundary line; choose any open object, such as line, arc, polyline, or spline.
Closed entities and 3D entities do not work.
Specifies the second boundary line.
Grips Editing
Ruled surfaces can be edited directly through grips:
  1. Select the rulesurf. Notice that it has one grip at each vertex.
  2. Drag the grip to move the adjacent faces.
Ai_Dish -  draws 3D dishes as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
