Block
Groups entities into a block (symbol).
command bar:  block
aliases:  -b, -block
menu bar:  Tools | Create Block
toolbar:  Draw 2D |
: block
Name for new block, or ? to list existing blocks: (Enter a name, or ?.)
Insertion point for new block: (Pick a point, or enter x,y coordinates.)
Select entities for block: (Select one or more entities.)
Select entities for block: (Select more entities, or press Enter to exit command.)
Name for new block
Specifies the name of the block.
Lists the names of blocks already in the drawing.
Press F2 to display Prompt History window.
Specifies the block's base point, the point at which it will be inserted into drawings with the Insert command.
Selects the entities that make up the block; you may use any selection method, including entity snaps.
Press Enter to finish selecting entities and to exit the command.
The entities disappear from view, but are now part of the block; use the Oops command to return the entities.
CopyBase - copies entities to the Clipboard with a base point.
Insert - inserts blocks and prompts for attribute values through a dialog box.
-Insert - insert blocks and prompts for attribute values through the command bar.
InsertAligned - inserts blocks repeatedly, and inserts mirrored blocks.
AttDef - defines attributes through a dialog box.
-AttDef - defines attributes through the command bar.
