Defines how a block's attributes will be created at the command prompt.
command bar: -attdef
: -attdef
Toggle attribute modes: Fixed: N/Hidden: N/Defined: N/Validate: N /<PROceed>: Enter an option, or press Enter.)
Name of attribute: (Enter up to 255 characters.)
Prompt: (Enter up to 255 characters.)
Default text: (Enter up to 255 characters.)
Text: Style/Align/Fit/Center/Middle/Right/Justify/<Start point>: (Pick a point, or enter an option.)
Height of text <0.2000>: (Enter a value, or press Enter to accept the default.)
Rotation angle of text <0>: (Enter a value, or press Enter to accept the default.)
This command is meant for use by macros, scripts, and LISP routines.
Sets modes for the attributes: |
Fixed: N |
Uses the default value; the user cannot change the value. |
Hidden: N |
Hides the attributes; they are not displayed and not printed. (Hidden attributes can be displayed with the AttDisp command.) |
Defined: N |
Inserts attributes without prompting the user; the attributes can be changed later with the AttEdit command. |
Validate: N |
Forces the user to enter the value a second time; this helps to ensure the value is entered correctly. |
<PROceed>: |
Press Enter to continue with the remainder of the command. |
Specifies the tag of the attribute; this is the name by which Bricscad identifies the attribute. You can use up to 255 letters, numbers, and punctuation. |
Specifies the user prompt; this is displayed at the command prompt when the attribute is later inserted in the drawing. You can leave this field blank; Bricscad uses the tag as the prompt during attribute insertion. |
Specifies the default value; this is displayed in angle brackets, like <360>. As with other defaults, the user need only press Enter to accept this value. |
Specifies the style and justification of the text:
Specifies the height of the attribute text, unless overridden by the text style or justification. Enter a value, or pick two points to indicate the height. |
Specifies the rotation angle of the rotation text. Enter a value, or pick two points to indicate the angle relative to the positive x axis. |
AttDef - defines attributes through a dialog box.
AttDisp - toggles the display of attribute text.
AttEdit - edits attribute values and properties.
AttExt - extracts attributes from drawings to data files through a dialog box.
-AttExt - extracts attributes from drawings to data files through the command bar.
Block and -Block - create blocks from attribute definitions and entities.
EAttEdit - edits attribute values and most properties.
Expode - reduces attributes to tags.
Insert - inserts blocks and prompts for attribute values through a dialog box.
-Insert - insert blocks and prompts for attribute values through the command bar.
InsertAligned - inserts blocks repeatedly, and inserts mirrored blocks.
Properties - edits attribute values and properties.
RefEdit - edits blocks and attributes in-place.
Bricscad™ коммерциализирован Bricsys NV. Bricsys NV и Vondle NV являются полностью дочерними компаниями Menhirs NV. Авторские права © 2001- Menhirs NV - Все права защищены. |
