InsertAligned
Inserts blocks repeatedly, and inserts mirrored blocks.
command bar:  insertaligned
alias:  insal
: insertaligned
? to list blocks in drawing/~ to open the file dialog/<Block to insert> <defaultname>: (Type ? or ", or enter the name of a block.)
Multiple blocks/<Insertion point for block>: (Type M to insert the block repeatedly, or pick a point to insert the block once.)
Enter block mirroring control point: (Pick a point to mirror the block.)
Lists the names of all blocks in the current drawing. Prompts you:
Block(s) to list <* for all> - press Enter to list all blocks, or enter part of a name to view some blocks.
If necessary, press F2 to view the full list. See TextScr command.
Displays the Insert Block dialog box.
Choose a .dwg file, and then click Open.
Block to insert
Specifies the name of the block to be inserted.
Multiple blocks
Repeats the following prompts until you press Enter or Esc.
This allows you to insert the same block many times quickly.
Specifies the insertion point of the block in the drawing.
Mirrors the block in one of four quadrants.
Move the cursor to locate the mirrored block; the block is mirrored about its insertion point.
Insert - inserts blocks into drawings.
-Insert - insert blocks and prompts for attribute values through the command bar.
AttDef - defines attributes through a dialog box.
-AttDef - defines attributes through the command bar.
Block and -Block - create blocks from attribute definitions and entities.
EAttEdit - edits attribute values and most properties.
Explode - reduces blocks to constituent entities and attributes to tags.
Properties - edits block and attribute values and properties.
RefEdit - edits blocks and attributes in-place.
