Works with Bricscad (Windows) Pro
Performs Boolean union operations on 3D solids and 2D regions; adds one to another to form a single entity.
command bar: union
alias: uni
menu bar: Modify | Solid Editing | Union
toolbar: Solid Editing |
: union
Select ACIS objects to union: (Choose one or more 3D solids and/or 2D regions.)
Entities in set: 2
Select ACIS objects to union: (Choose more ACIS entities, or press Enter to complete the command.)
The resulting solid takes on the properties of the first-picked solid.
3D solids that are joined through the Union command often look no different after the operation:
This command also applies to regions:
Specifies the ACIS entities to join into a single entity. Choose one or more 3D solids and/or 2D regions. The resulting entity takes on the properties of the ACIS entity selected first. This command also joins regions and 3D solids into a single entity. |
