Class AcadHatch
Member of BricscadDb
The Hatch object represents an area fill consisting of a pattern of lines. To create a hatch, first create the Hatch object using the AddHatch method. To query or edit an existing block reference, use the following methods and properties:
| Methods | Properties |
| AppendInnerLoop | Application |
| AppendOuterLoop | Area |
| ArrayPolar | AssociativeHatch |
| ArrayRectangular | Document |
| Copy | Elevation |
| Delete | GradientAngle |
| GetBoundingBox | GradientCentered |
| GetExtensionDictionary | GradientColor1 |
| GetLoopAt | GradientColor2 |
| GetXData | GradientName |
| Highlight | Handle |
| InsertLoopAt | HasExtensionDictionary |
| IntersectWith | HatchObjectType |
| Mirror | HatchStyle |
| Mirror3D | Hyperlinks |
| Move | ISOPenWidth |
| Rotate | Layer |
| Rotate3D | Linetype |
| ScaleEntity | LinetypeScale |
| SetPattern | Lineweight |
| SetXData | Material |
| TransformBy | Normal |
| Update | NumberOfLoops |
| ObjectID | |
| ObjectName | |
| OwnerID | |
| PatternAngle | |
| PatternDouble | |
| PatternName | |
| PatternScale | |
| PatternSpace | |
| PatternType | |
| TrueColor | |
| Visible |
