Class AcadPolygonMesh
Member of BricscadDb
The PolygonMesh object is a free-form mesh consisting of a series of connected polygon faces. It is identified as an M x N mesh where M represents the number of vertices in a row of the mesh and N represents the number of vertices in a column of the mesh. A mesh can be open or closed in either or both the M and N directions. A mesh that is closed in a given direction is considered to be continuous from the last row or column on to the first row or column.
To create a PolygonMesh object, use the Add3DMesh method. To access a PolygonMesh object, use the following methods and properties:
| Methods | Properties |
| AppendVertex | Application |
| ArrayPolar | Coordinate |
| ArrayRectangular | Coordinates |
| Copy | Document |
| Delete | Handle |
| Erase | HasExtensionDictionary |
| Explode | Hyperlinks |
| GetBoundingBox | Layer |
| GetExtensionDictionary | Linetype |
| GetXData | LinetypeScale |
| Highlight | Lineweight |
| IntersectWith | Material |
| Mirror | MClose |
| Mirror3D | MDensity |
| Move | MVertexCount |
| Rotate | Nclose |
| Rotate3D | NDensity |
| ScaleEntity | NVertexCount |
| SetXData | Parent |
| TransformBy | PlotStyleName |
| Update | TrueColor |
| Type | |
| Visible |
