Class AcadRasterImage
Member of BricscadDb
The Image object represents a raster image consisting of a rectangular grid of small squares or dots known as pixels. To create a raster image use the AddImage method. To edit or query a raster image, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | Application |
| ArrayRectangular | Color |
| Copy | Document |
| Delete | EntityName |
| Erase | |
| GetBoundingBox | Handle |
| GetExtensionDictionary | HasExtensionDictionary |
| GetXData | Height |
| Highlight | Hyperlinks |
| IntersectWith | ImageFile |
| Mirror | ImageHeight |
| Mirror3D | ImageVisibility |
| Move | ImageWidth |
| Rotate | Layer |
| Rotate3D | Linetype |
| ScaleEntity | LinetypeScale |
| SetXData | Lineweight |
| TransformBy | Origin |
| Update | Parent |
| PlotStyleName | |
| Visible | |
| Width |
