Class AcadCircle
Member of BricscadDb
To access the Region object, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | Application |
| ArrayRectangular | Area |
| Boolean | Centroid |
| Copy | Document |
| Delete | Handle |
| Explode | HasExtensionDictionary |
| GetBoundingBox | Layer |
| GetExtensionDictionary | Linetype |
| GetXData | LinetypeScale |
| Highlight | Lineweight |
| IntersectWith | Material |
| Mirror | MomentOfInertia |
| Mirror3D | Normal |
| Move | ObjectID |
| Rotate | ObjectName |
| Rotate3D | OwnerID |
| ScaleEntity | Perimeter |
| SetXData | PlotStyleName |
| TransformBy | PrincipalDirections |
| Update | PrincipalMoments |
| ProductOfInertia | |
| RadiiOfGiration | |
| TrueColor | |
| Visible |
