Class AcadTolerance
Member of BricscadDb
The Tolerance object represents geometric tolerance. To create tolerance, use the AddTolerance method. To modify or obtain information about a Tolerance object, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | Application |
| ArrayRectangular | DimensionLineColor |
| Copy | DirectionVector |
| Delete | Document |
| GetBoundingBox | Handle |
| GetExtensionDictionary | HasExtensionDictionary |
| GetXData | Hyperlinks |
| Highlight | InsertionPoint |
| IntersectWith | Layer |
| Mirror | Linetype |
| Mirror3D | LinetypeScale |
| Move | Lineweight |
| Rotate | Normal |
| Rotate3D | ObjectID |
| ScaleEntity | ObjectName |
| SetXData | OwnerID |
| TransformBy | PlotStyleName |
| Update | ScaleFactor |
| StyleName | |
| TextColor | |
| TextHeight | |
| TextString | |
| TextStyle | |
| TrueColor | |
| Visible |
