Sets or returns the scale factor for an object. Applies to following objects: Attribute, AttributeReference, Dim3PointAngular, DimAligned, DimAngular, DimArcLength, DimDiametric, DimOrdinate, DimRadial, DimRadialLarge, DimRotated, DwfUnderlay, Leader, MLeaderStyle, Raster, Shape, Text, Tolerance
Syntax
where:
doubleVariable is a double-precision variable (or value) representing the ScaleFactor property.
object is one of the objects that has a ScaleFactor property.
Examples...
