Class AcadDimAligned
Member of BricscadDb
A linear dimension displayed along a line parallel with a line connecting two points. To create an aligned dimension, use the AddDimAligned method. To access the DimAligned object, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | AltRoundDistance |
| ArrayRectangular | AltSuppressLeadingZeroes |
| Copy | AltSuppressTrailingZeroes |
| Delete | AltSuppressZeroFeet |
| GetBoundingBox | AltSuppressZeroInches |
| GetExtensionDictionary | AltTextPrefix |
| GetXData | AltTextSuffix |
| Highlight | AltTolerancePrecision |
| IntersectWith | AltToleranceSuppressLeadingZeroes |
| Mirror | AltToleranceSuppressTrailingZeroes |
| Mirror3D | AltToleranceSuppressZeroFeet |
| Move | AltToleranceSuppressZeroInches |
| Rotate | AltUnits |
| Rotate3D | AltUnitsFormat |
| ScaleEntity | AltUnitsPrecision |
| SetXData | AltUnitsScale |
| TransformBy | Application |
| Update | Arrowhead1Block |
| Arrowhead1Type | |
| Arrowhead2Block | |
| Arrowhead2Type | |
| ArrowheadSize | |
| DecimalSeparator | |
| DimensionLineColor | |
| DimensionLineExtend | |
| DimLine1Suppress | |
| DimLine2Suppress | |
| DimLineInside | |
| Document | |
| ExtensionLineColor | |
| ExtensionLineExtend | |
| ExtensionLineOffset | |
| ExtLine1Point | |
| ExtLine1Suppress | |
| ExtLine2Point | |
| ExtLine2Suppress | |
| Fit | |
| ForceLineInside | |
| FractionFormat | |
| Handle | |
| HasExtensionDictionary | |
| HorizontalTextPosition | |
| Hyperlinks | |
| Layer | |
| LinearScaleFactor | |
| Linetype | |
| LinetypeScale | |
| Lineweight | |
| Material | |
| Measurement | |
| Normal | |
| ObjectID | |
| ObjectName | |
| OwnerID | |
| PlotStyleName | |
| PrimaryUnitsPrecision | |
| Rotation | |
| RoundDistance | |
| ScaleFactor | |
| StyleName | |
| SuppressLeadingZeroes | |
| SuppressTrailingZeroes | |
| SuppressZeroFeet | |
| SuppressZeroInches | |
| TextColor | |
| TextGap | |
| TextHeight | |
| TextInside | |
| TextInsideAlign | |
| TextMovement | |
| TextOutsideAlign | |
| TextOverride | |
| TextPosition | |
| TextPrecision | |
| TextPrefix | |
| TextRotation | |
| TextString | |
| TextStyle | |
| TextSuffix | |
| ToleranceDisplay | |
| ToleranceHeightScale | |
| ToleranceJustification | |
| ToleranceLowerLimit | |
| TolerancePrecision | |
| ToleranceSuppressLeadingZeroes | |
| ToleranceSuppressTrailingZeroes | |
| ToleranceSuppressZeroFeet | |
| ToleranceSuppressZeroInches | |
| ToleranceUpperLimit | |
| TrueColor | |
| UnitsFormat | |
| VerticalTextPosition | |
| Visible |
