Class AcadDim3PointAngular
Member of BricscadDb
A dimension measuring the angular distance between three points. To create a 3-point angular dimension, use the AddDim3PointAngular method. To access the Dim3PointAngular object, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | AngleFormat |
| ArrayRectangular | AngleVertex |
| Copy | Application |
| Delete | Arrowhead1Block |
| GetBoundingBox | Arrowhead1Type |
| GetExtensionDictionary | Arrowhead2Block |
| GetXData | Arrowhead2Type |
| Highlight | ArrowheadSize |
| IntersectWith | DecimalSeparator |
| Mirror | DimensionLineColor |
| Mirror3D | DimLine1Suppress |
| Move | DimLine2Suppress |
| Rotate | DimLineInside |
| Rotate3D | Document |
| ScaleEntity | ExtensionLineColor |
| SetXData | ExtensionLineExtend |
| TransformBy | ExtensionLineOffset |
| Update | ExtLine1EndPoint |
| ExtLine1StartPoint | |
| ExtLine1Suppress | |
| ExtLine2EndPoint | |
| ExtLine2StartPoint | |
| ExtLine2Suppress | |
| Fit | |
| ForceLineInside | |
| Handle | |
| HasExtensionDictionary | |
| HorizontalTextPosition | |
| Hyperlinks | |
| Layer | |
| Linetype | |
| LinetypeScale | |
| Lineweight | |
| Measurement | |
| Normal | |
| ObjectID | |
| ObjectName | |
| OwnerID | |
| PlotStyleName | |
| Rotation | |
| ScaleFactor | |
| StyleName | |
| SuppressLeadingZeroes | |
| SuppressTrailingZeroes | |
| TextColor | |
| TextFill * | |
| TextFillColor * | |
| TextGap | |
| TextHeight | |
| TextInside | |
| TextInsideAlign | |
| TextMovement | |
| TextOutsideAlign | |
| TextOverride | |
| TextPosition | |
| TextPrecision | |
| TextPrefix | |
| TextRotation | |
| TextString | |
| TextStyle | |
| TextSuffix | |
| ToleranceDisplay | |
| ToleranceHeightScale | |
| ToleranceJustification | |
| ToleranceLowerLimit | |
| TolerancePrecision | |
| ToleranceSuppressLeadingZeroes | |
| ToleranceSuppressTrailingZeroes | |
| ToleranceSuppressZeroFeet | |
| ToleranceSuppressZeroInches | |
| ToleranceUpperLimit | |
| TrueColor | |
| VerticalTextPosition | |
| Visible |
