Polyline3D object
Class Acad3DPolyline
Member of BricscadDb
The Polyline3D object represents a polyline with three dimensional characteristics. To access the Polyline3D object, use the following methods and properties:
Methods Properties
AppendVertex Application
ArrayPolar Closed
ArrayRectangular Coordinate
Copy Coordinates
Delete Document
Explode Handle
GetBoundingBox HasExtensionDictionary
GetExtensionDictionary Hyperlinks
GetWidth Layer
GetXData Length
Highlight Linetype
IntersectWith LinetypeScale
Mirror Lineweight
Mirror3D Material
Move Normal
Offset ObjectID
Rotate ObjectName
Rotate3D OwnerID
ScaleEntity PlotStyleName
SetBulge TrueColor
SetWidth Visible
SetXData
TransformBy
Update
