Creates perspective views.
command bar: camera
menu bar: View | Camera
toolbar: View | ![]()
: camera
Specify camera location: (Enter a point to specify the location of the camera)
Specify target location: (Enter a point to specify the location of the target)
Enter an option [?/Name/LOcation/Height/Target/LEns/CLipping/View/eXit] <eXit>: (Enter an option or press Enter to conclude the command
A Camera glyph displays in the drawing to indicate the position of the camera.
A saved view is created in the drawing.
Displays a list of existing cameras. Prompts you: Enter camera name(s) to list <*>: Do one of the following:
Prompts you: Enter name for new camera <Camera1>: Type a name for the saved view or press Enter to accept the default name. |
Repositions the camera. Prompts you: Specify camera location <x,y,z>: Do one of the following:
Sets the Z-coordinate of the camera location. Prompts you: Specify camera height <current height>: Enter a value.
Repositions the target. Prompts you: Specify target location <x,y,z>: Do one of the following:
Defines the lens length. Prompts you: Specify lens length in mm <50.00>: Enter a value. |
Defines the front and back clipping planes. Prompts you: Enable front clipping plane? Yes/<No>: Type Y to define the front clipping plane. Prompts you: Specify front clipping plane offset from target plane <0.00>: Do one of the following:
Enable back clipping plane? Yes/<No>: Type Y to define the back clipping plane. Prompts you: Specify back clipping plane offset from target plane <0.00>: Do one of the following:
Sets the camera view current. Prompts you: Switch to camera view? Yes/<No>: Type Y, then press Enter. |
Concludes the command and creates the camera. |
Editing a Camera
Properties of a camera view can be edited:
i
Grips Editing
Cameras can be edited directly through grips:
AniPath - records the animation of a camera moving along a path or panning in a 3D model and saves it to a movie file.
DView - changes the 3D viewpoint interactively, and turns on perspective mode.
MatchPerspective - matches the current model space perspective view with a background image by selecting 3 or more matching point pairs.
View - creates and sets named views through the Drawing Explorer.
