Pro, Platinum
Pro, Platinum
Pro, Platinum
Creates 3D solids by revolution of closed 2D entities or regions about an axis.
command bar: dmrevolve
menu bar: Model | Direct Modeling | Revolve
toolbar: Direct Modeling |
(solid)
(surface)
Quad cursor menu: Direct Modeling |
(solid)
(surface)
: dmRevolve
When launched from the command bar, menu bar, toolbar or ribbon:
Select entities/subentities to revolve:
Select planar entities/subentities to revolve or set [MOde]: (Select a region or a closed 2D entity (closed polylines, circles and ellipses are accepted) or a face of solid.)
Entities/subentities in set: 1
Select planar entities/subentities to extrude or set [MOde]: (Select another entity or subentity or press Enter to stop selecting entities.)
When launched from the Quad cursor menu:
First select the entity, entities or boundary to be extruded.
Closed 2D entities (1)(2) and regions (2) are
accepted. Closed boundaries in the XY-plane of the current
coordinate system (4) or on the face of a solid (5) are recognized
automatically if the Select detected
boundaries option (
) on the Selection Modes
toolbar is active.
1 |
2 |
3 |
4 |
5 |
Do one of the following:
Launch the command when the desired entity or boundary highlights.
To revolve multiple entities: compose a selection set, then launch the command.
Select axial entity or define axis by [2Points/Xaxis/Yaxis/Zaxis] <2Points>: (Select a linear entity, or select an option, or right click to define the axis by two points.)
The selected entities are revolved dynamically. Move the mouse to specify the angle direction.
Specify angle of revolving or [Auto/Create/SUbtract/Unite] <Auto>: (Choose an option, then specify the angle.)
Specify angle of revolving or [Auto/Create] <Create>:
Allows to create either solids or surfaces. Prompts you: Choose type of created entity [SOlid/SUrface] <Solid>:
The Revolve tool ( The Revolve Surface tool ( |
Click an entity or choose an option in the dmRevolve prompt menu. Depending on the value of the DELOBJ (Delete Object) system variable, the defining entities are either retained or deleted or you are prompted whether to keep or delete the source entities. |
Select a linear (sub)entity as axis or define axis by <2Points>/Xaxis/Yaxis/Zaxis: |
Select a line or an edge of a solid. Edges of a solid can only be selected if the
Edges option of the SELECTIONMODES
system variable is set. |
2Points |
Specify start point of axis <0,0,0>: Specify the start point of the axis or press Enter to accept the origin point of the current UCS. Specify endpoint of axis or <use axis parallel to view direction>: Specify the end point of the axis or press Enter to set the axis parallel to the view direction (= perpendicular to the screen).
Zaxis |
Uses the x axis of the current UCS as the axis of revolution |
Yaxis |
Uses the y axis of the current UCS as the axis of revolution. |
Xaxis |
Uses the z axis of the current UCS as the axis of revolution. |
Press the Ctrl key to cycle the various options. |
The result depends on the extrusion direction of the 3D solid and the value of the DMEXTRUDEMODE system variable.
Regardless of the revolving direction, a new 3D solid is created. |
The 3D solid is subtracted from each interfering existing solid. |
The new 3D solid is unified with each interfering existing solid. |
* Repeatedly hit the Ctrl-key during the dynamic display of the extrusion to cycle the various options: Auto / Create / Subtract / Unite showing the result of the currently selected option. If TIPS is ON the Tips widget displays:
Loft - creates 3D solids passing through two or more cross sections.
Revolve - revolves 2D closed entities to turn them into 3D solids.
Sweep - creates a 3D solid by sweeping a closed 2D entity along a path.
dmChamfer - creates an equal distance chamfer between adjacent faces sharing a sharp edge.
dmDelete - deletes faces and solids.
dmExtrude - creates a 3D solids by extruding closed 2D entities or regions.
dmFillet - creates a smooth fillet between adjacent faces sharing a sharp edge.
dmMove - moves the selected faces or edges of a solid using a vector.
dmPushPull - adds or removes volume from a solid by moving a face or surface.
dmRotate - rotates faces of a solid around an axis.
