Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Draws 3D cones as mesh surfaces, with round or elliptical bases
command bar: ai_cone
menu bar: Draw | 3D Meshes | Cone
toolbar: Draw 3D |
: ai_box
Elliptical/Divisions/<Center of base of cone> <0,0,0>: (Pick a point, enter coordinates, or enter an option.)
Diameter/<Radius of base>: (Pick a point, enter coordinates, or type D.)
Apex/<Height of cone>: (Pick a point, enter coordinates, or type A.)
Specifies the center point of the cone's base. |
Specifies the radius of the cone's base. |
Specifies the height of the cone (in the z direction); enter a negative number to draw the cone upside down. |
Specifies coordinates for the top of the cone, an alternative to specifying the height. Prompts you: Apex of cone - specify the top of the cone by pointing or entering a height. |
Specifies the diameter of the cone's base: Diameter of base - specify the diameter by pointing or entering a value. |
Changes the number of isolines used to simulate the cone's curved surface. Prompts you: Number of divisions - change the number of isolines from the default of 1. |
Specifies that the cone should have an elliptical base. Prompts you: Center specifies the center of the ellipse. First end of ellipse axis - specify the endpoint of one ellipse axis. Second end of ellipse axis - specify the other endpoint of the first axis. Other axis - specify the length of the other (second) axis. |
Grips Editing
Mesh-formed cones can be edited directly through grips:
Select the cone. Notice that it has several grips.
Drag a grip to stretch the adjacent faces.
Ai_Dish - draws 3D dishes as mesh surfaces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
