Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Draws a sphere as a 3D mesh surface.
command bar: ai_sphere
menu bar: Draw | Meshes | Sphere
toolbar: Draw 3D |
: ai_sphere
Center of sphere: (Pick a point, or enter coordinates.)
Diameter/<Radius of sphere>: (Specify a distance, or type D.)
Specifies the center point of the sphere; enter x,y- or x,y,z-coordinates, or pick a point in the drawing. |
Specifies the radius. |
Specifies the diameter. |
Ai_Dish - draws 3D dishes as mesh surfaces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
