Class AcadDimension
Member of BricscadDb
The Dimension object represents a dimension in a drawing. Dimensions may be angular, linear, radial, or one of several other types. To create a dimension, use one of the AddDimXXX methods. To query or edit an existing dimension, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | Application |
| ArrayRectangular | DecimalSeparator |
| Copy | Document |
| Delete | Handle |
| GetBoundingBox | HasExtensionDictionary |
| GetExtensionDictionary | Hyperlinks |
| GetXData | Layer |
| Highlight | Linetype |
| IntersectWith | LinetypeScale |
| Mirror | Lineweight |
| Mirror3D | Material * |
| Move | Normal |
| Rotate | ObjectID |
| Rotate3D | ObjectName |
| ScaleEntity | OwnerID |
| SetXData | PlotStyleName |
| TransformBy | Rotation |
| Update | ScaleFactor |
| StyleName | |
| SuppressLeadingZeroes | |
| SuppressTrailingZeroes | |
| TextColor | |
| TextFill * | |
| TextGap | |
| TextHeight | |
| TextMovement | |
| TextOverride | |
| TextPosition | |
| TextPrefix | |
| TextRotation | |
| TextString | |
| TextStyle | |
| TextSuffix | |
| ToleranceDisplay | |
| ToleranceHeightScale | |
| ToleranceJustification | |
| TolearanceLowerLimit | |
| TolerancePrecision | |
| ToleranceSuppressLeadingZeroes | |
| ToleranceSuppressTrailingZeroes | |
| ToleranceSuppressZeroFeet | |
| ToleranceSuppressZeroInches | |
| ToleranceUpperLimit | |
| TrueColor | |
| UnitsFormat | |
| VerticalTextPosition | |
| Visible |
