Class AcadExternalReference
Member of BricscadDb
An instance of an external reference inserted into a drawing. To query or edit an existing external reference, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | Application |
| ArrayRectangular | Document |
| Copy | EffectiveName |
| Delete | Handle |
| GetAttributes | HasAttributes |
| GetBoundingBox | HasExtensionDictionary |
| GetExtensionDictionary | Hyperlinks |
| GetXData | InsertionPoint |
| Highlight | InsUnits |
| IntersectWith | InsUnitsFactor |
| Mirror | IsDynamicBlock |
| Mirror3D | Linetype |
| Move | LinetypeScale |
| Rotate | Lineweight |
| Rotate3D | Material * |
| ScaleEntity | Name |
| SetXData | Normal |
| TransformBy | ObjectID |
| Update | ObjectName |
| OwnerID | |
| Path | |
| PlotStyleName | |
| Rotation | |
| TrueColor | |
| Visible | |
| XEffectiveScaleFactor | |
| XScaleFactor | |
| YEffectiveScaleFactor | |
| YScaleFactor | |
| ZEffectiveScaleFactor | |
| ZScaleFactor |
