Class AcadLWPolyline
Member of BricscadDb
The LWPolyline (lightweight polyline) object represents a drawing entity composed of one or more connected line or arc segments treated as a single entity. To create a polyline, use the AddPolyline method. To edit or obtain information about a line, use the following methods and properties:
| Methods | Properties |
| AddVertex | Application |
| ArrayPolar | Area |
| ArrayRectangular | Closed |
| Copy | ConstantWidth |
| Delete | Coordinate |
| Explode | Coordinates |
| GetBoundingBox | Document |
| GetBulge | Elevation |
| GetExtensionDictionary | Handle |
| GetWidth | HasExtensionDictionary |
| GetXData | Hyperlinks |
| Highlight | Layer |
| IntersectWith | Length |
| Mirror | Linetype |
| Mirror3D | LinetypeGeneration |
| Move | LinetypeScale |
| Offset | Lineweight |
| Rotate | Material |
| Rotate3D | Normal |
| ScaleEntity | ObjectID |
| SetBulge | ObjectName |
| SetWidth | OwnerID |
| SetXData | PlotStyleName |
| TransformBy | Thickness |
| Update | TrueColor |
| Visible |
